Can anyone give me any feed back on the ebay clutch rand Bahnhof?
Old 06-06-2014, 07:48 PM
riplt1's Avatar
Default Can anyone give me any feed back on the ebay clutch rand Bahnhof?
I'm on a tight budget and found this brand on ebay. They have a stage 3 for about 250$ I'm making about 380whp.
I would normally stick with a brand I know (Ram, Centerforce, etc.) But I'm on a tight budget. Their stage 3's run close to 500$
Old 06-06-2014, 08:02 PM
madmike9396's Avatar
probably better off to wait and buy a good clutch
Old 06-06-2014, 08:31 PM
superspirit's Avatar
do a google search, they have bad reviews. I was considering one at one time decided it wasnt worth the risk.
Old 06-06-2014, 09:04 PM
MEAN LT1's Avatar
If your on a tight budget. I have a stocker that has plenty of life on it and a spec 3 in a good condition that I i'll be willing to let go really cheap.
Old 06-06-2014, 10:00 PM
Catmaigne's Avatar
I bet there's someone here who has a similar clutch setup who can shed some light. I think the biggest weakness is probably the disc itself lasting. But I wouldn't have high hopes for the lifespan of a cheapo clutch kit.
The disc included is puck style which will be nastier on the street. Dunno if that's a concern for you.
The kit also comes with the circular top throw out bearing. I broke 2 of them in my car and a friend of mine broke 1 in his. The circular flange always gets ripped off by the clutch fork. I upgraded to the square top TOB and haven't had a problem since (knock on wood).
The pressure plates are the same most of the time (#C70043 stamp). However, disc thickness can vary so some manufacturers mill extra material off the contact surface. Spec Stage 1 and 2 discs can be used with an OEM thickness pressure plate. Not sure about the Stage 3, but I know the 3+ that's in my car entails milling .040" from the PP. Other than it being thinner and having a blue powdercoat, I could find no discernible difference between the eBay PP that came out of my car and the Spec one when I put it in (both had the same # stamped into it). If the pressure plate in your car is fairly new then you could buy a disc from Spec for cheap and run it.
Old 06-22-2017, 03:46 PM
somerandommexicanguy's Avatar
Default clutch
I have purchased multiple clutchs from bahnhof and i have had a very good experience at first i was a bit sketchy but decided to risk it to be honest no regrets. and their customer service is very helpful
Old 06-23-2017, 11:43 AM
ShovelMan's Avatar
<sarcasm>
imo trust the person with 1 post.
</sarcasm>
Old 06-23-2017, 01:15 PM
BALLSS's Avatar
rip....check out Competition Clutch. They had a DF kit for less than $300 that had decent reviews
google shows this one
https://www.newegg.com/Product/Produ...9SIA6FZ3F82714
Old 06-23-2017, 05:46 PM
96lt1m6's Avatar
My last clutch was a competition clutch and I absolutely loved the performance especially on Sticky tires back to back runs.
Quick Reply: Can anyone give me any feed back on the ebay clutch rand Bahnhof?
