lt1 high rpm sputter
I got new good wires ordered and gonna put back in that loom some how holding it away from alt. But hopeful it's the new cheapo wires cause this issue.. I'm ready to pull my hair out over this.
I recently went through a similar problem. Replaced everything but the opti (I was in denial). Finally got so bad couldn't stand it and decided to replace opti. But, when I pulled the opti out the dowel pin came with it. Apparently it had broken off and under high RPM's became unstable and caused the miss. Not saying it's your problem too but ya never know.
Do you have a under drive pulley-harmonic balancer? My SLP pulley was messed up and the computer was seeing knock about 5 k and would pull timing out causing a miss fire. Drove me nuts till I changed it back to stock and it ran perfect. Spent hundreds of dollars chasing this. Shoulda sent SLP a bill. Pure junk stuff
after driving a couple more times still has a very small sputter at 5k
#33
i did put new taylor wires and spacers on it tuesday.. that fixed the one problem at 6k an up. but not the lil miss around 5 k just slipt second..
