24X Conversion
24X Conversion
FINALLY!
After years of 'thinking about it', but always stopping when it came time to part with the coin, I pulled the trigger on the 24x conversion.
Everything is ordered and on the way, except the harness and that would be on the way, except the Card tapped out and I haven't had a chance to get to the bank. They close at 4:00... . So I gotta wait until tomorrow to get that heading this way.
So this week end, I will pull all of the gear I just put back on the front end, AGAIN.
But! THIS TIME, when it goes back on, it goes back sans Opti-spark. And let me say: I'm not a hater of the Opti... the only problems that they ever caused me, were created by me. I just felt like to maximize the investment of the new heads, the porting of the heads and intake and the much more aggressive cam, that the limited rev-range relevant to said spark, was gonna hold us back. With the new breathers opened up I'll be able to pull her into the badlands, beyond 7k.
PLUS! With the LS PCM, I can pull into just about anywhere with a dyno and have a shot at getting a real, live, honest to goodness tune.
FINALLY... we may be in the verge of something truly NASTY .
And that's nice... .
It's about time buddy!
24x setup has sooooo many benefits over the stock PCM that it doesn't make sense to NOT run one for a big power NA build...the extra RPMs and ease of tuning are priceless.
The build is fairly straightforward. It's a continuation of the stroker build. (I broke the 96Z and am transferring everything to a new chassis.): 396ci, forged internals, LE assembled & ported AFR 210s, LE ported LT4 Intake, LE spec'd cam (for the first time since I've been doing this I'm holding back on the cam spec... but, it's the most aggressive cam I've ever used.), putting the A/C back in... adding BRM Anti-roll bar, Trak-pak control arm & sub-frame connectors. Plus the 24X conversion, of course.
I know right?
I can't wait... .
Called Strange today for a 4.10 setup, putting the intoxicating 5.13s out to pasture. (Anyone looking for a set of Strange 5.13s, 40 Spline gun-drilled axles and a 5 series spool for a Dana, let me know, they're SICK on the street... 'the great equalizer'.)
Turns out I have to change everything but the housing and axle-tubes. But I put the A/C back in and that means more cruisin' coming up. And it would be nice to not spend over a hundred bucks in gas, just driving to Bradenton and back, from Naples... .
I can't wait... .
Does anyone know if an LS MAF is needed or preferred for the 24X conversion? I'm currently using the Granitelli LT MAF.
Also... on the tune, who does the best job on startup conversion tunes?
I know right?
I can't wait... .
I know right?
I can't wait... .
