Lt1 valve seals
Old 09-15-2014, 09:30 AM
95sscamaro's Avatar
Default Lt1 valve seals
I was changing the header gaskets and I happened to pull the valve cover off to just check on how everything looked and I found these gems off in the corner of the head....
Old 09-15-2014, 11:03 AM
BALLSS's Avatar
you have the springs LE installed on the heads?
for double springs the valve stem guides are machined down for a smaller seal. mine are .500
looks like you have spring to seal contact or a damper inside the spring beat on them
Old 09-15-2014, 03:53 PM
95sscamaro's Avatar
yea the LE heads originally came with Crane triple springs but we replaced them with Duel lunati valve springs, and set them up just like LE said.
Quick Reply: Lt1 valve seals
