Engine idiot needing some help.
Old 11-25-2014, 07:51 PM
ErikEverhard's Avatar
Default Engine idiot needing some help.
Guys I have a 97 z28 that I need to change the EGR solenoid. I found this pic from shbox and is the part circled the EGR solenoid? I thought it was on the back on the intake drivers side?
Old 11-25-2014, 08:27 PM
93M6Formula's Avatar
No thats the EVAP purge solenoid IIRC.
The EGR is on the back of the intake like you said, can't miss it.
Old 11-25-2014, 09:22 PM
The way it looks it is pretty much a 10 min job, plug and play? Anyone know the size of the bolt I need to take off is?
Old 11-25-2014, 10:07 PM
BALLSS's Avatar
as noted the pic you circled from shbox site is the EVAP purge. The 411 on that site is right, you must have looked at the wrong link
shbox link for EGR location: http://shbox.com/1/egr1.jpg
there are "nuts" you take off to remove EGR
Old 11-25-2014, 10:17 PM
shbox's Avatar
The EGR solenoid is on a bracket attached to an intake manifold stud. 9/16" nut.
Quick Reply: Engine idiot needing some help.
