Project Blown Money Pit - 3rd Times the Charm
You seem to be doing good and doing it fast, I did my third build, going from a procharger to turbo some 3 years ago and only have app 10 miles on the new setup. Just been working on things that I should of done way back, Installed a line lock, rolled the fenders, installed a new viper 6 speed. Sending it to a shop to get some custom headers made and then try to figure out the biggest issue is, I cannot get the boost up, can only get 10lbs..Good to see your build going nicely..
So so this happened today....
Removed the rails from the car and took apart the regulator. I replaced the diaphram, all the o-rings and bolted everything back up. No leaks. The diaphram didn't look bad at all but there were a couple barely finger tight fasteners so I think that was the issue.
I only let the car run for a few minutes since I will eventually need to bleed the cooling system and the tuner needs to tweak my idle AFR. Everything out of the exhaust was water vapor from condensation. Not a bit of oil. Sooooo damn excited.
I didn't run the can long enough to really see how effective it was so I may give it another go.
Deleting it eh? We will see.
Really should have installed this gas heater in the garage years ago. Makes it a pleasure to work in the comfort while temps outside are sub-freezing.
Yes it is oversized but it was free and works great. I picked up a wireless thermostat so I can kick it on from anywhere and get the garage up to the desired temperature.
As for the car, I replaced the O2 sensors and wideband sensor. I've passed quite a bit of oil past the old sensors so a fresh set made sense. The MightMouse PCV can is hooked up. Factory PCV port gets connected to the inlet of the can. Outlet has a check valve which goes to the intake port below the throttle body. Passenger valve cover just gets a oil fill cap (no breather) and drivers side gets the breather. Hopefully it works as well as they say it should.
Got the car up to temp and AFR is looking good now. Coolant system took forever to bleed and I think needs a little more.
Now these roads need to clear up so I can take it for a ride!
#32
Wow, great reading and thx for sharing. U should have titled this one Blood, Sweat and Tears. And I think u deserve a dedication award for all your efforts to your LT1.
I see u installed a lot of UMI suspension hardware. I shopping now and dont know what to choose. The Spohn parts look great. Why did u choose UMI?
#33
I wish I could have a heater like that for free. I just simply refuse to work in the garage in really cold temps. However, I pulled my car out and let run for 15 minutes yesterday. Also, I'm going to was wax my GTP on Monday. Because it is going to 70 degrees in Denver...in February.
#35
The front K, upper/lower a-arms, torque arm and rear LCA's are all UMI. The drag bar is a BMR piece. Honestly, I started with the UMI stuff as they had (still have) a solid reputation, good prices and a well built product. I went with the BMR drag bar as this was a bolt-on piece not requiring any welding. Everything has worked well however the K was a little tricky to install.
Thanks!!
#36
Quick update. I had the car tuned at Tune Time in Lakewood, NJ last weekend and everything went very well. The car made very good power and the tune feels spot on from the drivers seat. The car starts, idles and drives very well.
Typical mustang heart breaker numbers but we will see what it does at the track. I did attend a dyno day (LTxTech.com hosted) this past weekend and below are the numbers on a dynojet. Peak boost was about 17lbs.
Mustang #s: 686rwhp/632rwtq
Dynojet #'s: 777rwhp/660rwtq (reading for tq was fubared due to tach signal issues)
