Oil pumps. High pressure vs high volume. Which would be better for my setup?
is your cam gear billet?
if not might want to stay with a stock melonized gear for the drive
I have seen pics of the all billet drive gear and also a "billet "cap" that goes over the plastic top to prevent breaking/cracking the stock plastic top. However, IMHO, just TQ to spec will prevent cracking the plastic stock one
Thanks for brining this up though. I would not have considered this.
As far as running the thicker VR1 racing 20W50 goes, I was told it also should be fine. Plus, due to the VR1 racing oil's high zinc content, it will be good for a turbo setup.
9-Second Club
I know several great professional race engine builders, none of who see any use for a high volume oil pump in any kind of SBC. Many use a LOWER volume pump (as I do) to save a few (As much as 5 hp has been observed numerous times). Why you would want your pump constantly bypassing oil? Does 65 psi oil pressure at idle makes you all wet?
I definitely agree. This is a street car that will see the track and is a manual. It's not a race car and the engine will be basically fresh as it's put back together. I trust my engine builder and his recommendation for the HV pump.
Ed, at least one bad LT1 builder seems to use 20w-50 and HV pump so he can just slap junk together loose and never measure or inspect anything. Then you have the scores of builders who haven't learned anything in decades.....
There is no valid reason to put a street strip motor together so loose you need a HV pump and 20w-50 to hold over 15psi at hot idle. Notice nobody commented on my point about oil pressure/bearing area vs. piston are and cylinder pressure to try and trigger some thoughtful discussion on what makes an oiling system work. People can't be bothered to understand........
9-Second Club
First, GM says 10 psi per 1000 RPM is sufficient. I think those engineers know more than anybody here. Any need for more than that is simply in your head.
Bearing life, nor anything else, won't improve with more.
Second, if you put an engine together with a high volume pump, and see a drop in oil pressure at idle, you seriously need to learn how to properly measure bearing oil clearances, and what clearances to use. One thousandth per inch of crank shaft journal diameter is pretty much what everybody I know uses. Before I learned better, I never saw any drop in oil pressure at idle with my stuff.
Anybody seeing 15 psi at idle with heavy oil like 20W40 made mistakes setting bearing clearances. RPM has a lot to do with required bearing clearances. That is why you see guys spin bearings with factory short blocks. The lower side of factory tolerances is too tight for 6000 + RPM. High side will usually live there.
Myself, I would not chance spinning a factory LT1 short block past 6000 without checking the bearing clearances.
#33
Man-Crush Warning
IDK thats what I am asking. If you go on the bullet, those guys build motors with much more HP than any LT1 owner can make and use tolerances that you are saying are completely silly.
So, do they know more, or do you. Only difference is you are NA and they are blower/turbo cars.
#37
9-Second Club
If you feel better listening to guys on yellowbullet, then that is who you need to listen to. I'm not going to go back and forth with you about this.
#39
Village Troll
I have no dog in this fight, but shouldn't low rpm/street driving be considered? All this sounds like high RPM/run motor for a 1/2 hour a night, living a 1/4 mile at a time race car talk.
#40
9-Second Club
All I posted was what the guys I work with build, and what they use, and what kind of power they were making, but if you preferred what the guys on yellow bullet were saying, then do what they say to do. I built my street engines the same way. Never an issue. My 383" went to Tennessee to be street raced. It was almost six years old, looked like new inside when I sold it. Others I built were done the same way.
Not sure what his smart comment was about. I'm done.
