LE1 Heads/Cam and LPP Headers Install Done! Videos/pics inside
haha, I told her to rev it and she didn't know what she was doing.
Me too. I wish it had more chop to it. The hotcam sounded better at idle. I figured it would have sounded better with the higher lift and duration. Maybe once I get it datalogged and fine tuned it will change some.
Where did you get the plug for the air fittings on your old headers? I had to bend and solder mine closed because I couldnt find a fine thread that size.
Also what tool and procedure did you use to pull the crank hub?
Are you going to get it dyno tuned? Or tuning yourself?
I bought a 7/16 threaded rod online, some washers and a bolt and installed it that way.
I have it tuned by Solomon right now. Im gonna have him loan me his tunercats and cable and data log it so he can fix whatever needs to be adjusted. The idle seems to be the only small issue as of now.
#33
Well the little LT1 did me proud today. I was driving behind a '13 Camaro SS 1LE today. He went into the passing lane on a back road out here and gunned it, so I downshifted into 2nd at about 35mph and stayed right on his *** until the top of 4th gear where we slowed down. I'm very happy with the way the car ran. It gives me a good indication of what kind of power I'm making. This was with 3.23's as well.
Seems Lloyd gave me exactly what I asked for, if not a tad bit more with this LE1 package. I'm a happy camper right now.
