95 LT1 no spark 1/2 hour after cap rotor replacement ???????
my friend asked me if I could swing by and check out his car ..... figured you guys might point me in the right direction before I get their .....
he replaced leaky water pump .... then he had a misfire...
so he pulled the pump back off changed cap rotor wires and plugs .......
says it ran 100% for 1/2 hour ....then died had to have towed home ...
says he has no spark from coil.. says it has no codes
he replaced coil and ign module and for some reason he replaced the maf???? still no spark
Lt1 is a little bit before my time ... I know just enough to get in trouble
any help would be appreciated
