30 lb SVOs with Le2 setup and possible nitrous?
Old 07-16-2015, 10:43 AM
Huntr1117's Avatar
Default 30 lb SVOs with Le2 setup and possible nitrous?
I have a set of 30 lb red tops that I was planning on using for my 24x 355 le2 setup and I'm thinking about possibly adding nitrous to the mix. Will the 30 lb red tops cut it or should I just go for some 42 lb green tops in case I do go with nitrous? I did notice that there is a similar post already but it has 2 different answers.
Old 07-16-2015, 04:14 PM
93M6Formula's Avatar
That depends, are we talking wet or dry shot? A wet shot should be okay with 30s. 42s would probably be needed for a dry shot depending on size.
Old 07-16-2015, 11:02 PM
Huntr1117's Avatar
It would be a 150-200 wet shot
Old 07-17-2015, 05:58 AM
bowtienut's Avatar
Then you're good with the SVO 30's. They will be plenty for any LE2 setup.
Old 07-17-2015, 07:09 AM
myltwon's Avatar
Assuming you're not running e85 its plenty for the setup
Old 07-25-2015, 10:55 AM
Huntr1117's Avatar
Thanks for the help guys. I'll stick with the 30 lbs.
Quick Reply: 30 lb SVOs with Le2 setup and possible nitrous?
