evap delete
evap delete
Im deleting my evap on my car, i cant seem to get a straight answer. What lines do i cap or delete, which one do i put a filter on, or do i just cap the lines and run a vented gas cap
IIRC, There is a line than runs from the tank to a Charcol canister? located behind the rear drivers tire. you need to put a filter on that line coming from the tank. This will act as the tank vent. After that you should be able to remove the canister, lines solinoind and all the rest of the junk. Also you will need to tune all the emmisions stuff out.
