lt1 swap, question about fuel lines
'm doing an lt1 swap (96 c4 lt1 into 80 c3). Anyone have any part names and numbers for high pressure fuel lines setup.
1) steel hard line, 3/8 compression to 3/8 barb hose line
2) steel hard line, 3/8 compression to 1/4 steel hard line
For #1, I bought this one then found out its for carb setup and it'll leak with 60psi:
http://www.jegs.com/webapp/wcs/store...2B13%2B1147708
can come up with any part numbers for #2?
For my swap I'm using the stock fuel lines that connect to the fuel rails (that is mounted to the intake)
