Lt1 low oil pressure
Village Troll
As stated, check with mechanical guage. If your oil sensor is just above the oil filter then there is a port just behind the manifold you can use.
It's possible the sensor is bad, however if the mechanical gauge matches what your sensor says, then it's time to take the engine apart...
