93 trans am
93 trans am
Hey guys, about 2 months back I bought this car and it ran perfect. I recently bought headers, NGK tr55 plugs, Jegs brand 8.5 mm wires, and erg delete kit. When I did the headers I did all of that also. When I got everything done I crunk it and it's has a bad miss. It misses at all time and the idle is fluctuating and backfires. I've tried taking the plugs out making sure right gap again and made sure all the plugs are seated and running to the right cylinders. I just changed the ignition coil yesterday and two days before that I changed the 02's. I ordered some more Taylor thunder volt 8.2 wires because the Jegs are the cheap thing that I have bought out of this whole deal and I hoping the wires are just bad. I have no idea what it is and I just don't want to keep guessing. Also it's not throwing any codes. Please help.
Also contrary to anyone's belief of gaining HP with bigger spark plug wires is silly, there is just no reason to run bigger wires unless you ARE making more power than stock, like a lot more than stock. Get some factory size wires. You should also check your motor mounts to make sure the new headers (I'm assuming long tubes) haven't made the motor sag and cause a very sensitive false knock related issue. And also, make sure no wires are burnt up/touching/arching against the headers.
I never thought of the mounts. I'll be sure to check that. The only reason I got bigger wires is because of the protective layer because that's the only thing going bigger than 7mm gives you is a thicker layer. I have already ordered new ones and if neither of that helps do you have any other ideas. The only reason I'm not leaning or wanting to say the opti is because it was parked for a few days while doing the headers and idk why it would go bad then. The weird thing is like the miss didn't just come up or anything. As soon as I crunk it for the first time it was missing horrible.
8.5mm wires fit in the stock wire looms. Have in mine.
OP, given you did plugs/wires I suspect you have one or more wires crossed so REALLY check again. Use dialectic grease on both plug & opti ends
You really need to be diligent in routing the wires as they are stock in all the brackets & looms so they don't lay against headers or catch on some spinning part
My new wires come in Tuesday. Driver side is pretty straight forward on routing and keeping them away from the headers which I've done with the ones I have. Pass side is straight forward to but kinda difficult to get them in the stock holders like you said and to run them like they were. And I have a diagram that tells me which cylinder goes to which port on opti. I will post it to show.
