Water pump and electronic ignition
Can't read diagrams. I need pics on how to wire my electric water pump with indicating light and ignition box. If anyone has one with the part number to the indictor light that would be awsome. Thanks guys.
The "indicator light" is any 12V light you want to use with power wire and ground wire.
There are diagrams floating around on how to wire the light into the circuit so it comes on when the water pump loses power (fuse blows) or loses ground connection. Basically whenever the pump is not energized.
You will need to become familiar with 12V car relays in order to do this. My Meziere was supplied with a inline 30A relay along with a inline fuse. This allows you to "trigger" the relay via a switched ignition wire (anything that is ONLY "on" when key is in KOEO/KOER position") which is how they tell you to wire it. When relay is triggered, it allows full current/power from battery circuit. I have my WP turning on when my fuel pump is energized..basically when I click my key over to "auxiliary" position it will turn on.
The light is a further step using the same relay but "opposite" how you wired the WP. This relay is always energized (when in KOEO/KOER) by the power going to the WP. If this relay loses power to it, which means the WP lost power, the warning light will light up.
I don't mean to sound like I don't want to help, but you are asking people to take pictures of every single wire and where/how it is wired is a lofty request...you want a specific write up "how to" with pictures which I personally don't have time to do/record.
If your weak spot is understanding wiring schematic then maybe you can ask someone you know that may understand it. Or have someone that knows wiring/mechanical aspects to do it for you.
I have a mechanical engineering degree, even though there are plenty of wiring schematics online showing how to do it they can still be confusing as to why someone did it the way they did. I did mine combining a couple different setups.
I can only suggest doing some research about wiring and use this as a learning process to broaden your automotive abilities.
