Almost Failed smog
Almost Failed smog
The High speed did not change much at all but the low speed did to the point where it almost failed. I havent really driven that car more than 2500 miles in the last year. Here are the results from 2005 compared to 2006.
Low Speed Results
April 2005 - 66,510 Miles
HC (PPM) Standard 117 Current Reading 15
CO (%) Standard 0.65 Current Reading 0.01
CO2 (%) 14.8
O2 % 0.4
NOx (ppm) Standard 879 Current Reading 441
Dillution (%) >6 14.8
April 2006 - 69,074 Miles
HC (PPM) Standard 117 Current Reading 108
CO (%) Standard 0.65 Current Reading 0.36
CO2 (%) 14.9
O2 % 1.0
NOx (ppm) Standard 879 Current Reading 213
Dillution (%) >6 15.3
Low Speed Results
CO2 (%) 14.8
O2 % 0.4
CO2 (%) 14.9
O2 % 1.0
Yeah I just got through going through the emissions crap. My car kept failing HC. It needed a .08 to pass and kicked out a .26
I replaced the converter with a high flow one. It did better .18 but it still failed. So I replaced the oxygen sensors and did a full tune up. $1500 later it passed.
I hate emissions.
I hate emissions.
Originally Posted by flame
How old is the gas in there? Crap fuel doesn't burn the same as fresh gas. I wish the limits up here were that high then I'd have no problem passing.
The gas was actually from the night before, the limit has come down here by almost half, ituse to be 220 on the HC
