383 Lt1 What Hp ##???????
Looking At A 383 Lt1 Stock Heads With The Hot Cam Kit What Kind Of Numbers Would I See With Long Tube Headers,58mm,3'' Slp Exhaust No Cats,in A T56 Car
That is a horrible setup and I would not trust anyone who would actually put it together with that poor a parts selection. It would be so weak head/cam stock bottom LT1s would would have no problem walking all over you. The stock castings are good but require porting if you want them on a 383 and can perform wonderfully if ported and just bolted to the stock shortblock with a cam upgrade. The HOT cam is a mediocre chopice for a 350 and downright poor choice for a stroker. You want to drop a couple grand on your car do the topend first then the bottomend with a new cam to compliment it down the road.
People say there is "no replacement for displacement" BUT if you don't let that displacement breath it wont work.
My Cars Got No Motor I Just Found This Motor I Already Have The Other Parts That I Listed He Says The Heads Are Mildly Ported And Cleaned Up So I Figure Thats Pretty Much Stock Heads He Most Likely Bought That Dam Hot Cam Kit After Reading It Will Make 425 Hp Which It Doesnt I Think I Would Change The Cam To A Gm 847 Or A 236/242.556/.576 Lsa 113 To Start Then When More Funds Are In Myhand Get A Set Afr 195 Cp Heads But My Question Is The Way This Motor Sits What Knids Of Hp Will It Make I Know Other Guys Out There Have Tried These Hot Cam's On Stroker Motors.
Who Out There Can Reburn Me Program For My Ecu I Live In Winnipeg And No Body Out Here Does This,i Want The Knock Senser Removed,tuned For What Ever Cam I Do Go With,egr Removed And All The Air Stuffon The Intake Removed?and If Possible The Rear 02 Senser Dont Want To Run A Simualtor
I would check out www.madz28.com Ion did a great job on my set up, theres a sheet on the website you need to fill out and go from there.
