Noise at start up.
Old 05-01-2006, 07:32 PM
Rare96WS6's Avatar
Default Noise at start up.
When I turn the ignition and the car starts to turn over I hear a
sound that is like some one saying "shhh" loudly. I sounds like a
slip of some kind. The car just started doing this in the last few weeks.
It does it every time I start the car now. Could it be the starter going out?
The car idles fine and the belt does not squeak while running, so I think
we can rule out bad belt and ignition. What do you think guys? I usually
only hear it once per startup in between the firing of the pistons. It sounds like rr rr "shhh" rr rr vrum, and then the car starts.
Thanks.
Old 05-02-2006, 02:33 PM
pontiacfireTAWS6's Avatar
I had somewhat of a "shh" sound after I changed plugs. I had a plug loose and you could hear it blowing through the threads. Thats the best advice I can give.
Old 05-02-2006, 02:37 PM
Rare96WS6's Avatar
Was this only on start up, or could you hear it all the time while the car was running?
