Need some help on gauges
battery voltage, oil pressure, and water temp you mean?
Battery, 12-13 volts, Oil Pressure 70-80 when cold 30-40 warm ( i think) and water temp if you have a stock thermostat should be around 195, in traffic it climb up to 220 or so and then the fans kick on, if it keeps going up you have a problem!
Your idle is fine, but I think you should check out your oil pressure, it seems really low. When i'm at a dead stop mine sits RIGHT at 20 and i'm kinda getting worried about it. I'm wondering if it's my oil pump. HOPEFULLY NOT
