swivel thermostat housing for lt1?
Originally Posted by 383LT1S10
Not that I've seen that will clear the intake elbow. I looked all over for one for my S10.
thanks
Oh in that case, there are several companies that make swivel housings. THough I have heard they tend to be leak prone unless you buy the high dollar ones ($80-$100). Look at summit or jegs.
You're running a Victor Jr with the holes angle drilled for the LT1 right? If so yes it will work.
yes im runnin the victor but the water passage on it is blocked off and i will be using the one on the lt1 water pump
thanks for the help
aftermarket, chevy, housing, leaking, leaks, longer, ls, ls1, ls1tech, ls7, lt1, swivel, thermastat, thermostat, thermostst
