Does a 58mm trottle body help???
Old 05-17-2006, 08:02 AM
Wickedws6ta's Avatar
Default Does a 58mm trottle body help???
Does a 58mm trottle body give any noticable power gains to a mostly stock car??? Also what would be a good short throw for a 96 6-speed???
Old 05-17-2006, 08:04 AM
the_merv's Avatar
Not really. You can only get so much air into a port. Bigger heads and stroker motors are good things to put a bigger TB on. Also anything with forced induction.
Old 05-17-2006, 08:05 AM
Thanks for the help man!!!
Old 05-17-2006, 08:09 AM
the_merv's Avatar
Invest that $200-$300 somewhere else, you will get better results.
Old 05-17-2006, 08:33 AM
smoknta's Avatar
I dont think it would help that much. You might also loose some throttle response.
Quick Reply: Does a 58mm trottle body help???
