Need a complete list for cam swap, please
I called comp cams help line but the guy gave me some weird numbers, some lead to ls1 parts.
I am planning on the cc305, and i need to know what part/p#s i need to do the job.
Do i need a timing chain set? I can use the stock rockers right? Need new springs i know that, pushrods, lifters...thats about all i know that i need.
Just need the parts to do a cam swap and have the car running.
here is what i went with.
Comp Cam 224/230 .503/.510
Comp Lifters
Comp 915 Beehive Springs
Comp Locks
Comp Retainers
Comp Pro Maginum 1.6 Rockers
Comp 7/16 Rocker Arm Studs
Lunati Timing Set
GMPP Guide Plates
u can go without the rockers but id would go ahead and replace them. if u are looking for bare minimum id say replace the cam, timing set, lifters, pushrods, and springs. most the springs say LS1 but will work on both i have the 915's but the 918's are a tougher spring.
Comp sells Cam kits which will include the basics and it will be parts that work well with eachother just make sure and tell them its a LT1 because i ordered mine online and ended up having to send my cam and timing set back because lt1's are different than all other 350's.
Comp Lifters
Comp Locks
Comp Retainers
Lunati Timing Set
GMPP Guide Plates
