94 4L60E trans interchanges to 95 4L60E?
hey guys,
I am new to the board. I have a question, I have a 94 camaro LT4 that needs a trans and I found one from a 95 camaro Z28 that can handle my horsepower. Will a 95 4l60e go into my 94 camaro? If not, what do I have to do to make it right? Thanks
From a quick search:
No mechanical mods required. Mod A must be performed. The trans will operate normally without Mod A but TCC lockup will not work, so highway and cruising gas mileage will suffer and more heat will be produced in the transmission.
Mod A (method 1):
An additional wire must be run from the PCM pin TBD to pin TBD on the trans harness for the TCC to work. Also, the PCM must be reprogrammed with ’95 transmission base code.
Mod A (method 1):
