Where to buy OEM lifters?
I believe Crane Cams has both versions Hydraulic and Solid that fit into the Dog Bones. I am using the solid.
This is the hydraulic part#
Part Number: 10535-16
Application
CHEVROLET V-8 87-98, 305 AND 350 CU. IN. AND LS1 5.7L
Description
Long travel design for 87-98 blocks originally equipped with hydraulic roller cam and lifters. A necessity when camshafts have greater than stock lobe lift or reduced base circle diameter. For use with standard GM alignment bars. a To order spares, you may order any of these lifters in pairs by removing the -16 from the set part number and replacing it with a -2. For example, a 11532-16 set will become a 11532-2 when ordering one pair.
Application
Description
