Victor E Intake
Uhh the vic E already has bungs and stuff and rails actully in the new kit. I just need to know the bolt patter .. do i have to slot some holes or something. What u are talkin about is way off.
The Victor E already has the bungs and you can get the rails with it that bolt up nicely to the intake. This intake is rated at 4000-8500 rpms but needs a lot of porting. By far the easiest way if you want to do the conversion is to go with this intake. The Super Vic is a very good choice as well but more work is involved and sits higher (need more hood clearance). As far as the bolt pattern......you can drill the intake to fit the heads or weld up the heads and re-drill the heads for the intake.
