HELPfast doing headerinstall
Old 06-28-2006, 11:40 AM
Bad Seller Warning!
96 LT-1's Avatar
Default HELPfast doing headerinstall
ok guys taking out thedriver side header.... and i broke off what looks to be some kind of sensor going into the block what is it??? its right after the first 2 bolts....
Old 06-28-2006, 11:59 AM
-PEPE-'s Avatar
believe it's your water temp sensor and it's on the head not the block if it's the driver side. Or if you broke off a sensor further down on the oil pan that's your oil level sensor.
Old 06-28-2006, 12:02 PM
streetwarrior96's Avatar
water temp sensor
Old 06-28-2006, 01:36 PM
the_merv's Avatar
What exactly broke on it, the plastic plug, cause that piece is solid metal.
