Stock polished crank for 355 force fed setup?
Can I use my stock crank on my forced fed 355 setup? Also is it worth the money to have it internally balanced, or should I have it balanced at the flywheel...? Being that I have a zero balanced billet steel fly wheel from spec...
The block is a 2bolt going to get some JE dished pistons and eagle 5.7 forged rods... Planing to put around 10- 12 #'s of boost... Do you think it is wirth internally baling it or shold I just buy an eagle kit for 1,600?
If you're doing a 355 I'd put 6" rods in it...... you can definitely keep the stock crank if you want....
My stock cranked 355 went 10.40 and was still runnin strong when i pulled it apart...... but yeah internally balance it....
