1992 Corvette + 95 Camaro engine = ???
Old 07-04-2006, 10:08 PM
Honda Hunter's Avatar
Default 1992 Corvette + 95 Camaro engine = ???
I have the motor and tranny from my camaro. What all would it take and how much would it cost to install it in a 92 corvette?
Old 07-05-2006, 01:02 AM
GTP PWR's Avatar
same engine, just different exhaust setup. relatively cheap. I'm looking to do the same thing when I find the right vetter. I want a manual trans.
Old 07-05-2006, 01:13 AM
infinitebird's Avatar
yeah, that won't be hard since it's the same. 92 vettes came with the lt1 also.
Old 07-05-2006, 01:37 AM
harvickgm's Avatar
the vette fuel rails are different i beleive... i know the blocks are slightly different, vette block is a 4 bolt main... you may have to buy some little peices but thats it... will still work, and the tranny will not work... unless you can somehow get the PCM from the 95 to work in the vette with the wiring harness.. the 92 vette was a speed density car so there was no MAF and came with a 700r4 not 4L60E... but if its a manual...it should work.. im sure there are some others that i just cant think of right now..
Old 07-05-2006, 04:04 AM
the_merv's Avatar
Also, the Vette and the Camaro Motor Mounts are in different places I believe..
