Help Me Spend My Money!!
ok so im looking to put some money into the camaro and i was hoping to do all labor myself and maby friends help.....here is the list u tell me what order and what type ect.
-headers and cutout
-cam
-slp fan switch
-suspension
-springs
-shocks
-subframe connectors/thinking 3point
-torque arm
-somthing for stearing forget what its called-panhard maby?
-gears maby 4.10's?
thats what im thinking so far. i want this to be more of a street car that can be a semi dd......even though i have a truck
-headers and cutout
-cam
-slp fan switch
-suspension
-springs
-shocks
-torque arm
-gears maby 4.10's?
160 Thermostat (might as well do if you do fan switch)
Slp Fanswitch
All suspension btw its panhard bar (can buy either weld on or bolt on parts )
cutout (cutout needs welding)
headers
as for cam&gears they are about as equally hard, cam a little more so, unless you have ALOT of expirenence with both go to a professional...rear end gears are not something you wanna mess around with by yourself if you dont know what your doing, btw 4.10s are good gears for M6's ( a typical gear install will cost about 500, and a cam 800+ *i think* could be more though)
As for what you SHOULD do heres the list:
SLP CAI
160 thermo
manual fan switch
change plugs and wires depending on your mileage
synthetic motor oil
throttle body bypass *free mod*
strut brace
pacesetter LT headers and y pipe
4.10s
find a better flowing muffler (unless your happy with the sound)
with all the stuff about you should feel and see a nice gain you wont be disapointed
now for the stuff I didnt say.....
forget the suspension stuff unless your putting down alot of power and have traction problems its a waste of money
and as for cam thats all up to you, just make sure you do the research and get the right one for your set up. the cc305 and 306 are popular cams with us LT1 owners.
What you wanting the car to do, ie the intended reason for buying the parts?
To go fast in a straight line, around corners or on the street?
What ever you want, weight reduction is where the biggest gains are at!
