need help!!!
Old 09-17-2006, 05:54 PM
dropped94formula's Avatar
Default need help!!!
ok i have a 94 formula that i just got done installing a new motor, stock heads stroked and 305 cam, USED opti. its throwing these 2 codes
16 A low resolution pulse was not detected by ECM within 720 high resolution timing pulses.
36 ECM detected less than 40 high resolution timing pulses between each low resolution pulse for 5 consecutive cycles.
any ideas? thanks for the help, much needed
p.s. it also will idle down to 500 rpm and die a bit after, its also hard to start.
Old 09-17-2006, 11:12 PM
ttt also wouldnt start for a while, then disconnected the coil wire (4 prong above the intake) and started right up, anyone????
Old 09-18-2006, 12:14 PM
ttt anyone???
Old 09-18-2006, 12:29 PM
Dean95z28's Avatar
Not exactly sure but maybe you should check your knock sensor, and if you haven't already change the lt1 to a lt4 knock module in the computer
Old 09-18-2006, 01:33 PM
jldak318's Avatar
ignition controll module, try that first. if the car runs great until it heats up and is throwing them codes its prob the icm.
Old 09-19-2006, 12:06 PM
thanks ill try those two out. any other ideas?
Old 09-19-2006, 12:12 PM
Bad Dad's Avatar
Check your opti wire harness connections.
Quick Reply: need help!!!
