fuel enable bypass
fuel enable bypass
Just stuck in the new LT1 engine in the 97 camaro after a year of building. It starts then dies due to the bcm not sending a message to the pcm via the fuel enable circuit. Theft and passkey circuits ck out ok. how can one bypass this circuit so the engine can remain running with out replacing any more parts. Note teh pcm was sent out for a reprograme so we could run the engine and do some seating in and set teh car up enought before it gets dyno tuned. thanks bigmel
Have a ALDL cable and a Laptop you can plug into? Maybe tune out the VATS (Vehicle Anti Theft System) and see if that might do it. Was your key dropped or something and the pill got damaged?
If I'm misunderstanding you, my apologies. I would double check all sensors, plugs, relays and fuses.
