383CI LT1 How much power?
Im running a 383 LT1 11:1 Comp. Stage 2 heads 2.0 1.5 Valves. the XFI Camshaft 292XFI 584 574 242/248 Victor E Converted for LT1 block, Intake Elbows Elbow, 58mm TB, Beehive springs, 1.6 Comp RRs, Its going through a th400 and 10 bolt right now but eventually 9". Plan on spraying a 150 shot and 200 on special occations. TCI 4500 Stall. What kind of power do you think im looking at? What kind of Track times are you guys perdicting as well?
I'd have run more compression, especially with that big cam. The IVC is pretty late at 75 ABDC. That only gives you 8.06 DCR which leaves a lot of room for improvement, AFAIK. I'm running 11.5:1 in a 355 with a slightly smaller xfi grind and getting 8.7:1 DCR. DCR isn't the end all be all, but just the first thing I noticed. I'd like to see how the superram helps you out. Did you get the beehive 918 springs? There's a guy running that cam in a 396 running low 11's. He loves it.
