bottom end kit
bottom end kit
came across this on ebay. what you guys think sucks its not forged but you think its worth getting to built a 355
http://cgi.ebay.com/ebaymotors/SB-CH...spagenameZWDVW
i wouldnt buy a kit if i were you. you can put a better setup together for yourself for little to no extra cost. in almost every case youll find that some aspect of a "kit" isnt want youre wanting. if forged isnt important to you i would go with an eagle crank, some good manley forged rods(lighter bottom end=higher and faster revs), and your choice of pistons depending on the heads and compression ratio youre looking to achieve. theres alot more to it then just throwing a motor together with a kit. people do it all the time and end up not getting the desired result so do your research and know your parts and make the right decision the first time so you dont end up kicking yourself.
That is the same kit I was considering. I think the kit is a very good deal and I think you will be hard pressed trying to find a better deal on another assembly or reusing stock parts. This is the average stock rebuild quote I've been recieving: crank grind $100, stock rods recon $150 w/arp rod bolts, balance $150, pistons & rings kit $200, rod & main bearings, $70, pressing in piston pins $50 = $720 total. The only reason I see not to buy this kit is if you wanted forged pistons for spray or boost.
