i need and M6 to A3 (th350) write-up
i'm sure this might get moved to one of the tranny sections, but i kind of want lt1 specific help. all of my 6 speed parts are out of the car (1993 z28). i'm in no particular time frame of putting the car back together, but i want to have all the parts for the conversion at hand when i begin. the biggest concerns that i have are wiring issues of the old clutch start switch, nuetral saftey switch, and reverse lights.
if some has a link to a write up, or a sticky on this, i would appreciate it.
personal experience is also VERY welcome.
-jeff
-jeff
It's not that hard.
Get a wiring diagram to begin with, Haynes manual will be fine. The new 3spd shifter will need micro switches and just wire it up. OR for the N switch, you can just jump it and it will start the car in any gear, may not be a wise thing but easy!
Swap out the M6 pedals for A4 pedals, get a flywheel.
Decide what Torq Arm you are going to use. I like to get the TA off the trans, then just add some material to the A4 crossmember and get a TH350 with a 9" tailshaft or get a new DS. I like the Madman dipstick tube specific for the trans you get.
