pro's and con's of retarding cam timing?
look at my sig, for all my mods. but:
I'm running a comp 503 and a cloyes double roller timing set. the crank gear has the ability to set cam timing up in -4*, 0*, and +4*...
seeing as I have a 4.11 gear and a 6spd, while at the track, my car RARELY ever sees under 4500rpm, maybe on launch (which is at 5k-6k) so low-end power is something that I can somewhat trade off for.
are there any adverse effects to retarding the cam timing 4* other than the loss of low-end power? any guess as to how it will help my top-end power?
doing this, would probably make a single plane (that I am already dedicated to) shine even better than it would with the cam set straight up (no advance, no retard)
if it hurts low-end, and doesn't help top end, it's only a water pump, and timing cover gasket swap away from the way it was.
BTW: BEFORE anyone says it, I know tuning would be in order, and I've already talked to my buddy about doing it, he says it wouldn't be a problem to re-tune it.
There are almost no Pro's doing this.... Only time is when you want to shorten up the intake duration of a cam, keep the same exhaust events and the same IVC. Then you have to retard the cam to do this.
I referr to a retarded cam as being installed with a ICL higher than the LSA.
Most times a single plane will not get help from this.
Bret
Bret
Bret
Bret
damn, shot that all to hell
well, atleast I didn't waste my time/money on doing it.
