Dry kit on LT1 Anyone spraying in front
Old 01-27-2007, 03:53 PM
jakesz28's Avatar
Default Dry kit on LT1 Anyone spraying in front
I posted this in the nitrous section but I'm puttiing it here hopefully to get more response out of LT1-4 owners
Dry kit on LT1 Anyone spraying in front of the MAF? I was wondering if I could spray a dry 100hp in front of the MAF? If I add the dry kit I dont want to go the route of spiking the fuel pressure. I will be going with 42lbs or higher injectors. I currently have a dynotune 150 wet and was considering going DP. But if I can make this work and spray 250-300 total in two stages, while spending less money I'm sold.
Old 01-28-2007, 12:33 AM
seawolf06's Avatar
I was told that the pcm is not fast enough for that. Dunno how it would work as a second stage, though.
Old 01-28-2007, 09:49 AM
camar0corey's Avatar
I've been wondering, is it our MAF or the PCM? Just wondering as someone mentioned a while ago about running LSx MAFs on the LT1.
Old 01-28-2007, 06:46 PM
seawolf06's Avatar
It's the pcm. The MAF is almost the same IIRC.
Quick Reply: Dry kit on LT1 Anyone spraying in front
