need help!! spark plugs
i have a 95 ta m6...bolt ons and a 75 dry shot (that i have not sprayed in months) and my car is backfiring like crazy...it did not do it when i had ac delco plugs and when i switched to ngk tr55 it started to get hot and backfired after a month or so...is it the plugs? do i need colder or just get ac delco again??? i have the ngk's that i am about to put in? should i? are they the right plugs? gapped at .50 thanks
Sounds like you might be getting some spark blowout. Check the gap -- but definitely with any forced induced application the TR6s are the way to go. Just make sure they're gapped correctly (.035)
