Conector mod
Conector mod
A while back someone made a thread where they took the 2 Connectors on the passenger side Wheel Well near the PCM and ran them under the Fender. I did something a little different with them.
I took both of them and made them into 1. For all you guys that deleted AC, you can go through the wires here, and take out the ones that you don't need. It opens a few spots up, and I ran the wires off of the 8-pin onnector(C-105) to the 10-pin Connector(C-100). I got bored and figured I would mess with the Car a little bit and see what I can do with them. It will also help my Harness swap, I wired the other one to plug into this the same way.
