Timing Set Question......
I was just wondering what makes the lt1 timing gears different from early SBC timing gears besides the water pump drive.
If i was to remove the water pump drive could i run any older sbc timing sets?
thanks for your input
If you remove the water pump drive you can runa a 86-up factory roller cam timing set. Earlier pre-85 TC's aren't compatible with the retainer or bolt circle on the face of the LT1 cams.
