96 harness swap on 94 LT1
Old 02-14-2007, 07:18 PM
94transamguy's Avatar
Default 96 harness swap on 94 LT1
I did a (96 PCM/Harness) swap on my (94 T/A) and my main question is, will my (94 LT1) run w/o the (96 crank position sensor) that is required on the (96 LT1 PCM)?..There is a crank sensor pigtail on the (96 harness) and i have no female for it to plug into since my LT1 didn't come stock with a crank position sensor built into the timing cover from the factory.So i need to know if my car is going to run since i have no female for it to plug into, and if so is it possible to have it tuned out, like the two post-cat O2 sensors that i dont have on my car.
