FIPK Cleaning
FIPK Cleaning
Alright, random question. While ago when I had my waterpump off, I was looking at my K&N Cone filter.. those come red, don't they? If the thing is solid black, what should you use to clean it? Shame on me for letting it get so dirty. haha, oh well.
Originally Posted by jb442
Simple Green works pretty good for cleaning K&N filters in my experience, but you'll still need the filter oil.
I have run K&N filters for over 25 years on my motorcycles. As stated above, you can use ordinary dishwashing liquid to clean them. Be sure and clean them from the inside out, that is run the water into the center to wash the dirt out of the filter material. Be sure and let them dry thoroughly before applying the oil. You can use an air compressor if you are in a hurry, again from the inside out. You must use their oil, as mentioned above. At one time they made it in a spray can, but I have not seen that for a while. And don't over oil them, either. Your car will run rich until the oil is sucked out. If properly maintained, they will last forever.
