As it is correct to install cam drive pin installed
HI,
Problem Beside me, I have not looked when repair drive pin cam gear.
Prompt, where in opti must keyed to be when installing. C4--92.
Thanks.
Thanks.
huuh? are you asking where the cam gear goes? or where the opti goes? or where the pin goes into the opti? are you sure you have the right opti? there are two different kinds. the shaft will be different on the two different styles.
repost and take your time you be a little more clear to us. we would love to help you if we can understand what you need help with. i see you are in Moscow, so i understand the difficulty.
