lt1 slow after 100?
lt1 slow after 100?
I think somthings wrong with my car its slow after 2nd gear, i have a th400 and when i hit third gear my friend always passes me me in his 02 ws6 6spd. I also get like 10 mpg and my torque seems low at just 337 ft lbs. my mods are in my sig. what could be the problem??
Has your car always done this? First, you need gears on that thing. Second, Do you have good programming? Last, hp relies on your heads and cam. You need more HEAD!! and maybe a bigger cam to see the 400 hp numbers.
how about more compression like say maybe 11:1 would be good since its a stroker motor. and definitely need to step up to some 3.73s or higher. and honestly i dont know why you have a th 400. youre losing a lot of power and and picking up more weight too. i would swap back out for a built th 350, get 3.73s and i would say you should be hitting in a low 12 and pulling harder up top.
Originally Posted by lt1383
STOCK GEARS 2.73 NEED GOO..
342 or 373
I miss my 700R4 I would rape ls1 six speed all time. But now with TH-350 I think iam one going get rape ..
342 or 373
They are sluggish for the most part though, I agree 2.73's stink.
That can be fixed by one of three ways
1) Stall
2) Gears
3) Both!
your tq numbers do look a little low, but then again its thru an auto and a stall...you're 1/4 mile times look a little low also...hows your tune? and you DEF need a gear...3.73s or so
your 3 speed tranny is the problem, what was wrong a built 4l60e that belongs in the car? n e way thats your problem i can bet, your gears are too far apart with a non OD tranny
3 speed trans will have gears farther apart, just adding over drive wont take that lat out of 3rd, with a trans thats originally OD will have less of a drop naturally becouse the trans was geard to have 4 gears
i dont think the gears are that much farther apart on a 400 compared to a 700R4. 3rd gear is 1 to 1 in both of them, and the 700 just has an extra gear after that. they both have 2 gears befor that, and i doubt they are noticably different than each other.
the th400 is pretty close ratios 2.48:1, 1.48:1, 1:1, thats closer than the 4l60e was, but i think i reallly need the 3.73s in back ill see what that does, im goin to get it retuned again as soon as i get my new rear end and NX kit hooked up, then I may get some afr 195s and slightly bigger cam later this summer. thanks
yea, gears will wake the car up some, but might not really help at speeds of the kind you're talking about. smaller gears get you going quicker, but the further you go, the less good they're gonna do. i'd still say try gears, but nothing too steep. stay below the 4.0's.
