Hooking up problems
Hooking up problems
Okay guys just like the tittle says. I can't hook up for crap at the track. Do I need bigger tires
I got all the suspension (look in link)
QA1 shocks are 2 - front 1L/2R - rear (L=LEft, R=Right)
M/T 26'' x 10.5'' - 16''LT ---- I think the tires are kinda small?
good burnout in the box
getting out of the whole side ways
No nitrous yet
No nitrous yet
try having someone watch what the rear of your car is doing when you launch hard. does it "squat", is one side much higher then the other, stuff like that. because you can adjust most of that with the springs and shocks.
No nitrous yet
No nitrous yet
MAN- GM vehicles suck!
Originally Posted by LT1MAN
what is your pinion angle set at?
pinion angle is set at -2.... I'll try -1. and stiffening the rear shocks
putting 421 RWHP and401 RWTQ.
The one time it actually caught the posi broke in three parts, the time before that the yolk, driveshaft broke.
Originally Posted by nodnarb481
you obviously need more horsepower dude.. i mean i couldnt hook for **** either so this weekend im doing new valvetrain..
streetwarrior96, you pretty much have everything for the rear suspension. Maybe LCA relocation brackets will help some? After that, all you can do is tweak everything. Go ahead and change the pinion angle and stiffen the rear shocks, then see what happeneds.
yes it was a joke haha.. wow i was hoping that wouldnt shoot over anyones heads.. i got relocation brackets like stated right above and they helped a lot. but with a 383 lt4 its gonna take a lot of sticky to keep your tires planted. do you have a 12 bolt? never forget no amount of suspension can make up for shitty tires
Originally Posted by 97blkz
You always need more HP, lol! What psi were the tires ran at?
Originally Posted by Ralls
This has to be a joke, who would be this stupid?
I got LCA (BMR Boxed) with the relocation brackets
