CAI install questions...
hey guys, i was installing my moroso CAI yesterday and ran into a few problems:
what is the best way to get that plate down in there w/o tearing stuff up?
right now i just have the filter there because i just wanted to get the car running so i could test drive it.
what could be the reason my headlights will not flip up now? the lights come on, but the motors aren't trying to turn. did i forget to plug something back in or pinch a wire or something?
thanks for the help.
Can't really help with the plate issue as mine went right in without any hassle, I had a friend underneath the car helping me guide everything into place, but as far as the headlights, may wanna check the control module as its right around where you're bumping around with the Cai mounted on the driver side strut tower, may have knocked the harness loose. Thats what tells the motors to spin and raise/close the headlight assemblies.
EDIT: actually after looking at mine I forgot that I put mine under the the fuse box after installing the CAI (did that 3 years ago so memory was short), because it was in the way of the cai install lol, so yeah, im almost certain thats whats wrong, you probably yanked it around to move it out of the way and now your head lights aren't working. I bolted mine to the inner fender to get it out of the way. Its a little black box with 2 harnesses loaded with wires plugged into it. You'll know it when you see it.
