LT-4 Springs?
A lot more than lift has to be considered. The HOT cam is very mild lobes and achieves the .525 lift through rocker ratio which is easier on springs than moving the heavy tappet as much. Basically the ONLY setup I would recommend them on is 1.6 rockers on a stock cam, would not even recommend them on a HOT cam.
