383 Stroker LT1 help!
Old 04-13-2007, 02:08 AM
silly454's Avatar
Default 383 Stroker LT1 help!
I am putting a 383 stroker LT1 in my 95Z but am not sure what cam to use and throttle body size. My car is a M6 and I have 4.11 gears with a TA girdle. I am looking to be around 425 RWHP and want the car to pull hard through the entire spectrum if possible. If you guys have any ideas please let me have them. Thanks.
Old 04-13-2007, 02:14 AM
hashtagBMW
Speed Density's Avatar
Contact some companies for camshaft designs.
A few of our sponsors:
www.cdnperf.com
www.portpros.com
www.thunderracing.com
www.totalengineairflow.com
And a 58mm TB will suite you just fine. Any of the manufactures will work.
Tony.
Old 04-13-2007, 08:49 AM
rbrcka's Avatar
Just make sure if you go bigger than a 52mm throttle body that the intake manifold is opened up at least as big. When I got my car it had a 58mm, but the intake had not been touched so there was a big wall for the air to hit.
Old 04-14-2007, 02:19 AM
silly454's Avatar
Yeah I am having the intake opened up to 60mm so it should be good.
Old 04-14-2007, 12:49 PM
TWS
TWS's Avatar
Yep. Get a 58mm. I have an ASM 58 that I've been using and have been happy with it.
Old 04-15-2007, 03:42 AM
silly454's Avatar
Now what cam do you all think? Also should I go with 30lb or 37lb injectors?
Quick Reply: 383 Stroker LT1 help!
