Tach and speedo jumping around at WOT!
Old 05-12-2007, 07:11 PM
ele-blue95's Avatar
Default Tach and speedo jumping around at WOT!
The tach and speedo started jumping around at the track today. The more i run the worse it gets. IT does not do it on the street. I believe it is a bad ground, but i do not know were the ground strap is of the gauge cluster. Any help would be great.
Old 01-22-2010, 01:56 PM
artist71's Avatar
bump on this subject
Old 01-22-2010, 02:03 PM
Puck's Avatar
Check your grounds and battery voltage. My car did the same thing with a dirty ground terminal on the battery.
There is a large ground strap on the engine block.
Quick Reply: Tach and speedo jumping around at WOT!
