Throttle Body Bypass on a 94..
Well was going to to the throttle body bypass but can't find any info on what to do if you have the T coming off the bleader pipe I guess. The metal pipe that has the screw in it to bleed out the air.
Right now i have nothing going to the nipple under the throttle body.
Would I have to find a way to replace that entire line or is there another trick to block off that T?
Mike
Mike
Thanks,
Unfortunatly I know about that how-to and it isn't the same on the 93-94 models as we have a T that comes off that metal bleeder rod in the middle of the hose.
Mike
Mike
on my 94 there was a tube on the right of the throttle body going onto the knub on the TB then out the other side and into a T on another hose....
I took the tube from the right and connected it to the right side hose, never messed with the T kuz that is totally diff.... Plugged the knubs....
oh ok, where exactly does the hose that is directly under the throttle body opening go to?
Mine has never had that hose since I bought it. I just got a bunch of wiring done so moving on to some of these things and noticed it's not even there.
Mike
Mike
