Welding bunds into the radiator hose?
I moved my radiator and bought the radiator specifed in this thread
https://ls1tech.com/forums/showthrea...8&page=2&pp=20
Im trying to get water back into the radiator. When my new rad showed up theres epoxy where the core hits the tank. I dont want to melt that when i tig a fitting on the new rad so im thinking of putting fittings into my hose going back into the radiator. Anyone see a problem with this?
I need to weld a -8 bung on the hose and a 1/4 fitting. Also What hose is the return hose on the LT1. I was thinking the hot side exiting the motor is the hose coming from the drivers side
I just drilled holes in the rad tank on the side basicly where the stock line was comming back from the heads. heres a pic where I drilled them before it was welded.
